Decrease Turn Radius?? Any Mods? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 09-10-2013, 09:34 AM Thread Starter
I am really hating the idea of selling my 01 CCLB, but it is a bear with a 60+ foot turn radius. Has anyone figured out a way to decrease the turn radius??
- shaving steering stops??
Is it possible to move leaf springs inboard ????
mram10 is offline
post #2 of 13 Old 09-10-2013, 09:40 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Use '05 up axles and suspension....
CT Performance, Inc. is offline
post #3 of 13 Old 09-10-2013, 09:47 AM Thread Starter
How hard is that to do? Sounds easy
How much does it decrease turn radius?
mram10 is offline
post #4 of 13 Old 09-11-2013, 12:13 AM Thread Starter
I am really not wanting to sell the truck so I am going to try the following:
1. Change wheels from 0 offset to -24 offset
2. Get more narrow tires, so they don't hit the leaf springs
3. Adjust the steering stops to match when tires just touch leaf springs
After all that, I will measure to see if I can get the 62' I have now down toward the 56' that an 06 cclb has. I'll keep you posted guys.
mram10 is offline
post #5 of 13 Old 09-11-2013, 07:06 AM
Quoted: 6 Post(s)
With the money you spend on new wheels & tires, you could buy the front axle off a wrecked 05 plus the other parts and do the swap.
2006 F250 CC/SB 6.0 Diesel
SCT 3015, Straight Piped
2002 F350 CC/SB 7.3 Diesel- SOLD
-PHP Hydra, 6637, Diamond Eye DEP-510215 Muffler Delete, GlowShift Triple Gauge Cluster.
-Plans: JW Valve Body & 6.0 Torque Converter/Cooler
bikeluver43 is offline
post #6 of 13 Old 09-11-2013, 08:41 AM Thread Starter
I have yet to find a really good DIY of the 05 swap. I am needing a list of materials, so I can get started. I saw the kit that someone sells(can't remember) and it was over 5k !! Junk yards are my friend
mram10 is offline
post #7 of 13 Old 09-26-2013, 06:49 PM Thread Starter
I decided to get some -24 offset wheels to keep the tires out as far as possible. I then cut the steering stops back about 1/2 inch. Now, it turns a lot better. No other mods should be needed to make it turn tighter. I am very happy with it now
mram10 is offline
post #8 of 13 Old 09-26-2013, 06:58 PM
Quoted: 28 Post(s)
I'm sorry to say but with the offset soo far out there you might wear out the ball joints faster...
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #9 of 13 Old 09-27-2013, 08:10 PM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 17 Post(s)
Not so much with a -24 offset. He'll be okay.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #10 of 13 Old 09-27-2013, 09:18 PM
BIG Laing's Avatar
That is less then 1" further out then stock.... nothing to worry about.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
