Transfer case stuck in neutral - Ford Powerstroke Diesel Forum
post #1 of 6 Old 08-24-2013, 09:52 PM Thread Starter
On my way home from work the truck slipped into neutral. This happened a few days ago and I assumed the worst. At that time was able to get under the truck and found the transfer case linkage had disconnected from the shifter. I grabbed the linkage and shifted it back into 2wd. Today the same thing happens. I roll into a parking lot and figure "no biggie, probably just slipped back in neutral". Well this time it won't find a gears regardless of what position I put the T case in. It's as if something is screwed up internally on the T case. It still has 4 definitive solid positions when I move the linkage. Doesn't feel sloppy or loose or anything, yet it still can't move. Headed over to where I left it in the morning and having to flatbed it to the garage. Any ideas????
nepa7.3 is offline
post #2 of 6 Old 08-24-2013, 11:32 PM
JSchuricht's Avatar
I read about someone having the same issue a while back. Turned out to be a shift fork in the transfer case.
JSchuricht is offline
post #3 of 6 Old 08-25-2013, 05:54 AM Thread Starter
I'm leaning that way too. Picking it up now and I suppose dropping the T case. I'll take pics of the issue once I diagnose it
nepa7.3 is offline
post #4 of 6 Old 08-25-2013, 03:07 PM Thread Starter
Well it needs the range shift fork. Having a hard time finding any and I need the truck back on the road ASAP. Any ideas where I could get it quick? If not i might have to get a used T case quick
nepa7.3 is offline
post #5 of 6 Old 08-25-2013, 11:33 PM
JSchuricht's Avatar
Lots of them on google.
post #6 of 6 Old 04-17-2015, 02:53 PM
heykw's Avatar
Did it make a loud piping noise when it went into neutral?
Excursion 02 4x4 Silverline exaust superchip tuner
Excursion 2000 4x4 300K miles 238/100 P.I.S. Injectors 38RW/ billet wheel dyno proven tunes
99 F350 7.3 4x4 body build date 02/98 motor build date 12/97 19.5 ricksons (Sold)
heykw is offline
