Truck stalls in drive - Ford Powerstroke Diesel Forum
post #1 of 18 Old 08-21-2013, 06:19 PM Thread Starter
Exclamation Truck stalls in drive
I have a 00 f350 7.3 n everytime i put it in deive it stalls. I just bought this truck off a company that used it for a plow truck n rentals. It has 193 600 km on it. I cant figure put whats wrong with the truck. I only used it for a day before it started stalling out. It idles perfect. Good in reverse. But drive 2 n 1 at take off it will stall. I changed the fuel filter. Cleaned the air filter. Anyone can help me out with the problem?
Bfelix88 is offline
post #2 of 18 Old 08-21-2013, 06:26 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
the torque converter may be locked, when was the trans serviced last
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 18 Old 08-21-2013, 06:31 PM Thread Starter
Im not to sure. Is there anyway to free the torque converter?
Bfelix88 is offline
post #4 of 18 Old 08-22-2013, 03:20 AM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
it should be electric lock up. there should be a connector going to the side of the trans. disconnect it and see how it runs . don't know what is also connected to the trans , but this worked on an old chevy i had years ago.
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
post #5 of 18 Old 08-22-2013, 09:54 AM Thread Starter
Ok ill try that out after work n c if it works.
Bfelix88 is offline
post #6 of 18 Old 08-22-2013, 01:06 PM Thread Starter
If my converter is locked up n i cant find anyway to unlock it n i keep using it tell i get a new one will it wreck anything else. I cant seem to get it to unlock. Is there any other way to unlock it?
Bfelix88 is offline
post #7 of 18 Old 08-22-2013, 01:30 PM Thread Starter
Im new to all this so any help would be good. First time owning my own truck n it just had to be a 7.3 n not a gasser.
Bfelix88 is offline
post #8 of 18 Old 08-22-2013, 01:42 PM
Quoted: 787 Post(s)
Could be a pcm or a trans solenoid issue.
Corey@CNCFAB is offline
post #9 of 18 Old 08-22-2013, 01:59 PM Thread Starter
Where is the soleonid located? I am gonna be asking lots of questions since i am in my 20s n this is my first ever truck. N im in a town were there is no mechanics for 1200 miles.
Bfelix88 is offline
post #10 of 18 Old 08-22-2013, 02:03 PM
Quoted: 787 Post(s)
Inside the transmission. Try this. There is a plug that is on the driver side of the trans. It goes into a black plastic box that's about the size of a post card. Unplug it plug it back in. Make sure you hear it click when plugging it back in.
