transfer case engaging going down the highway - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-16-2013, 05:17 PM Thread Starter
02 F350 4X4 280k
Never had any issues before today but started a 2kmi trip yesterday and about 200 mi into it 75mph, looked down and the 4wd light was on. checked switch position it was in the 2wd position so I stopped put truck into 4wd and into low range then back into 2wd... all shifted fine so I took off down the road again. got up to speed no more that 1/2 mi down the road I hear a grinding noise and I think the transfer case locked in and the 4wd light was on again. as I pulled off the light went off again as before.
I put the transfer case through the motions again and when in 2wd I unplugged the motor on the transfer case. rest of the trip with no issues, unplugged.
I guess I will be looking for a short somewhere tomorrow, but I wanted to post it up to see if anybody has had any of the same issues to give me a starting place.
thanks Fletcher
2002
350 4X4 Dually Crew Cab
S&B intake
Edge Evo2
TW 6position chip
stage 1 Injectors
ATS turbo Housing
4"Magnaflow turbo back stainless exhaust
Rear load leveler Air ride
Rancho air adjustable shocks all 4 corners
B&W goosneck hitch
SCDEALER is offline
post #2 of 5 Old 07-16-2013, 05:21 PM
sargar's Avatar
I've not heard of that but the 2 relays have caused plenty of problems of not shifting correctly. You may want to look into them.
Tuned, Deleted, Filtered, Monitored...all the usual stuff.
sargar is offline
post #3 of 5 Old 02-27-2014, 02:21 PM
Have had same issue with my 01 F-250. I know it is NOT suppose to be possible, but mine tried to go into 4- low, thought the rear end was about to tear out from under the truck. Happened twice within 3 or 4 miles, and has not happened since. I did change both relays, don't know it that was causing the problem, but hasn't happened since.
Outagas is offline
post #4 of 5 Old 02-18-2015, 09:21 PM
I recently posted another thread concerning this same issue. Glad I found someone else that had the same problem. My was making the noise and then it sounded like a clunk or something as I was slowing down, but that might've just been me, but after that my 4x4 light won't come on and won't shift into 4x4. So what turned out to be the problem?
robtholm is offline
post #5 of 5 Old 02-20-2015, 09:05 PM
According to the mechanic that changed out the two relays under the hood on the passenger side of my 01 f-250. His theory was that one of the relays had possibly shorted internally and was sending a signal to engage actuator motor. Not sure if this was the issue, but have not had any more issues since they were changed.
Outagas is offline
