4wd common issues - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-06-2013, 01:49 PM Thread Starter
Underpowered's Avatar
4wd common issues
2000 F350 4x4. 4wd has always worked since i have owned it. Today went to turn around in the yard, and with the monsoon like weather we are getting here in the mid west, i needed 4wd to do this. turned the switch on the dash......and nothin.
i had manually locked my hubs in prior to this. no light on the dash or anything. i checked fuses, and they all seem to be good. I figured i'd ask if there was a common Issue to know what to check first, or if it is crapshoot that every other issue seems to be with these things.
'89 K5 Trail Rig--not at all stock
'98 Jeep ZJ DD-nearly stock
'00 F350 Tow Pig- bone stock.
Underpowered is offline
post #2 of 8 Old 07-06-2013, 02:31 PM
whiteghost1999's Avatar
check the electrical connectors going into the transfer case.
whiteghost1999 is offline
post #3 of 8 Old 07-08-2013, 05:50 PM Thread Starter
got it. upper plug on the t-case was loose. clips are broken on it apparently
post #4 of 8 Old 07-09-2013, 06:23 PM
mine has stopped letting me use 4 low. sorry to thread jack but thought it would fit well in this thread. truck is in neutral with my foot on the brake and it wont shift. 4 hi works just fine. 4 low light comes on with i first turn the key but it wont shift into low. just stays in 4 hi.
greasemykey is offline
post #5 of 8 Old 12-08-2015, 09:51 AM
Powered by Coors Light
EasyRhin0's Avatar
Hey I know it has been a while, but did you ever figure this out? I have the same problem and am looking through threads.
Thanks
Dave
Thanks,
Dave
2001 CCSB F250 4WD
135,XXX miles on the clock
MKM Custom 05-07 Grill, 05-07 headlights, S&B Intake, Dieselsite Boots x6, HPx, NC Hornet CCV Mod, Headlight Relays with SiverStars
, MBRP 4" Turbo back 5" Tip, 203 T Stat and Billet Housing.
My favorite quote - "There's no replacement for displacement!"
EasyRhin0 is offline
post #6 of 8 Old 12-13-2015, 09:24 AM
Quoted: 3 Post(s)
Same issue here. Checked all fuses - good. Couldn't find specific relay so checked all of them - good. Does this just leave the T-case actuator?
EDIT: Just checked for voltage at T-case motor connector when switching ESOF and nothing changed. SO appears to be electrical issue. Manual states there are 2 relays (positions 40 & 41) related to shift on the fly. Where are these located?
TIA,
Milo
Milochi is offline
post #7 of 8 Old 12-17-2015, 09:29 PM
Quoted: 60 Post(s)
Next to the underhood fuse box, there are two aux relay pods. Each one has 2 relays in it. One of them is the T-Case relays, the other is Trailer Tow Battery Charge. Sorry, I don't know which pod is the T-case.
DaveP. is offline
post #8 of 8 Old 02-27-2016, 05:54 PM
wy00powerstroke's Avatar
Good thing I came here to check for some information on what might be wrong with the electrical issue of my transfer case. now I also need to find a place to work on it so I can get under the darn thing. I will be checking the relays next to the power box under the hood in the morning.
wy00powerstroke is offline
