auto locking hubs to manual hub quick question. please help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-23-2013, 09:31 PM Thread Starter
first off, im new here and i apoligize for the long post. i have 01 f250 7.3. it came with AUTO locking hubs. i just recently discovered my hubs were shot. my passenger side hub was always locked spinning my front drive shaft even in 2wd. and when i removed the driver side i found numerous peices of plastic laying inside there and the hub came out in 2 peices and then the spring, whereas my passenger side came out in one whole peice.
my question is, i have my mind set on going with WARN manual locking hubs, probably the premium ones. and i was all set to order them until the guy at my local napa suggested i have to get a hub conversion kit. so i did a little research and to my understanding the 5 bolt auto hubs you DO NOT need the conversion kit, and the 3 bolt hub you DO need the conversion kit which consists of a spindle bolt i believe? how do i know if i have the 5 bolt or the 3 bolt? i looked, and the hubs i removed i couldnt see any bolts at all, just a big clip i squeezed to remove and i pulled the hub out.
any one who has any knowledge on this is greatly appreciated, as im running my truck without the hubs in it now. and i am hoping to order them tomorrow.
if anyone is curious, the hubs are 317$ and the conversion kit is like 120 bucks from my local napa. i personally think its a little high, but i need them quick.
thanks in advance.
if it helps this is what my CURRENT hubs look like.
Brand New Pair Auto Locking Front Hubs Ford F250 F350 F450 Excursion | eBay
mike
2001 f250 lariat 7.3l ONLY 99K MILES
-4" diamondeye turbo back straight pipe
-5" RBP tip
-intake
-120hp edge evolution CTS
-westin bull bar
-07' front end conversion
-12' rear end conversion/bed and tail gate
-04' 18" chrome wheels
-PLATINUM SERIES gauge cluster
deezl250 is offline
post #2 of 6 Old 06-24-2013, 01:39 PM
blue99stroker's Avatar
Quoted: 246 Post(s)
first off you dont need a conversion kit.
and 317 dollars is outrageous!
most places online sell them for 220-250.
also make sure you cap the vacuum lines that run to the hubs.
and also cap the fitting on the hub itself so stuff doesn't get in there.
ive also heard good things about mile marker hubs. they are 154 on xdp.com
and you can use the code diesel5 for 5% off.
or try diesel10 for 10% off it might still work.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 6 Old 06-24-2013, 01:56 PM
DirtyDiesel's Avatar
Quoted: 3 Post(s)
That's a rip off. All they are is regular old Dana 60 lock outs. Should be in the low 200s at NAPA. We put a set in my dads 00 350 a while back after his 3rd one broke.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #4 of 6 Old 06-24-2013, 02:26 PM
Converted my 2001 over to manual hubs and were less than $200 on amazon.
2008 Silver F-250 6.4
griz700rocket is offline
post #5 of 6 Old 06-24-2013, 09:39 PM Thread Starter
ya i understand there priced a little high, it helped a little that i got a volunteer fire fighter discount which got me down to 275. but like i said i need them quick as i am currently running the truck with the hubs removed, because one of them was broken into 3 peices, and found little peices of plastic inside.
so as far as the HUB CONVERSION kit, does anyone know what it actually consists of? i am totally confused, as everyone at the parts stores is giving me different answers. i mean i even called my local ford dealership this afternoon and the guy had no idea what i was talking about, and mentioned something about having to shave down the WARN manual hubs to fit?? never heard that one, so one more thing i may need to look into.
appreciate all replies so far. more info is greatly appreciated.
thanks
mike
-5" RBP tip
-intake
-westin bull bar
deezl250 is offline
post #6 of 6 Old 06-25-2013, 04:13 AM
Quoted: 3 Post(s)
For regular type hubs no conversion is needed, just remove the stock plastic hubs and install the warn ones. Idk about the premium version.
Brett
