popping noise in rear axle? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 06-05-2013, 07:38 PM Thread Starter
FEAGLEY 2010's Avatar
I have a 2000 ford f250, ever since I've bought the truck when you make a right turn there is a popping,chatter noise it sounds like from the rear axle. I drained and cleaned the gears NO metal shavings or chunks. Put fresh oil and friction modifier in and it still does it. I'm running out of ideas it could be. It needs shocks could it be that? HELP!!!!
FEAGLEY 2010 is offline
post #2 of 20 Old 06-09-2013, 07:27 PM Thread Starter
Anyone got anything????
post #3 of 20 Old 06-10-2013, 03:00 PM
blue99stroker's Avatar
Quoted: 249 Post(s)
is the LS unit going bad and locking up when you turn?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 20 Old 06-10-2013, 03:21 PM Thread Starter
Is there a way to check it??
post #5 of 20 Old 06-10-2013, 03:31 PM
ZMANN's Avatar
Quoted: 1457 Post(s)
I would expect the LS to behave the same on a right or left turn if done at the same radius
I mention the radius since left turns in real world driving are usually much wider of a turn
post back on that and you could try some more additive
We Miss you Ronnie
ZMANN is offline
post #6 of 20 Old 06-10-2013, 05:43 PM Thread Starter
So add more friction modifier. Is there nothing else I can do
post #7 of 20 Old 06-18-2013, 04:17 PM Thread Starter
Alright guys I put more additive in it. Still pops. The two things I think it is is driver side 4x4 shaft is locked up won't budge at all. Then the sway bar bushing sound like they need to be replaced. But it still sounds like the rear end. Can it be e brake leaf springa shocks anything. HELP!!!!
post #8 of 20 Old 06-19-2013, 02:03 PM Thread Starter
post #9 of 20 Old 06-19-2013, 02:29 PM
Verndog's Avatar
Quoted: 3 Post(s)
Check your away bar bushings!
2012 F250 Lariat, 5.5 Icon, Icon resi's, 37" Toyo's, XD Hoss, Amp Research, SDHQ Longtravel air bags w/ On-board air, 50 gal Transfer Flow tank.
Verndog is offline
post #10 of 20 Old 06-19-2013, 02:31 PM Thread Starter
Both front and rear??? Will they cause that popping
