front axle needs ujoint - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-31-2013, 04:15 PM Thread Starter
i have a bad ujoint on the left front of my f350 super duty 02 year model. my question is do i need to knock the housing loose from the ball joints or will the axle come thru it like the f150's? never did one of these it looks like a seal in the back of the housing would keep the axle from comming thru. thanks for your help in advance.
superduty2 is offline
post #2 of 5 Old 06-01-2013, 05:01 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
It comes right through, you'll need to do something about driving the new (and expensive) Knuckle Seal in. Here's a tool you can make.
Ford Super Duty Knuckle Seal Tool - AKA OTC 6695 | Superdutypsd.com
Ford Super Duty Ball Joint Replacement Procedure | Superdutypsd.com
A good vid on replacing the Ball Joints, but it shows the dissassembly and axle pull clearly.
And a good resource for anytime you go into the hub
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
NoRalPh is offline
post #3 of 5 Old 06-01-2013, 07:44 AM Thread Starter
Thumbs up
Thanks so much NoRalPh for the info the video was great. i'll make me one of those tool's with 1 1/4" pipe. again thanks
post #4 of 5 Old 06-02-2013, 07:34 PM
Roc87's Avatar
Just did ball joints and hubs. Some mechanic told me I could use a brass drift and get those axle seals put on (of course that didn't work) so I didn't have a chance to order the correct tool and I don't have a vice to use the home made tool. I took the axles to a dealer and had one of their mechanics put the seals on....He used an old hub!
'01 F250 7.3 PSD 4x4 EC SB. AFE Stage II, Banks 4" turbo-back, turbo housing & IC, Wicked Wheel 2, Rosewood 160cc/80 Single Shot Injectors, Beans Tunes, OilGuard bypass, Riffraff FRX & HPX, Zoodad, Harpoon, '04 18" rims, '07 Front & '08 Rear.
Roc87 is offline
post #5 of 5 Old 06-07-2013, 06:04 AM Thread Starter
Thumbs up
well got the f350 done. someone had put the big washer in backward's and didn't have the 3 washer's in right order. thank's again for the viedo
