What am I looking at? - axle questions. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-11-2013, 01:42 PM Thread Starter
Once you go black......
CanadianDiesel's Avatar
Send a message via MSN to CanadianDiesel
I thought my hub was maybe finished, again. Took everything apart (With hub still on, lots of shaft play..)
At this point, here are my questions: (see pictures)
1. Should the shaft have a lot of play?
2. Is there another bearing in there, or is that a vacuum seal?
3. Why so much black powder??
I appreciate any kind of insight on this...thanks guys.
Then & Now
Matt
'99 F-350 4x4 7.3L
6637, 4", chip; far too many upgrades to list.
Coming soon: Rigid Industries Lighting, Nav, On-Board Air.
Latest mods: Line-X, '08 Black Leather Captain Seats (Lariat), Trans, EGT and Turbo Gauges; TS chip, Chrome Delete.
02 VW Jetta TDI - 40mpg
CanadianDiesel is offline
post #2 of 4 Old 05-11-2013, 02:18 PM
ZMANN's Avatar
Quoted: 1476 Post(s)
it's a seal and that has been neglected
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
We Miss you Ronnie
ZMANN is offline
post #3 of 4 Old 05-11-2013, 03:08 PM Thread Starter
Mine looks like sh!t compared to his. I have manual locking hubs though, so I guess I don't need to be too concerned about vacuum.
Then & Now
Matt
'99 F-350 4x4 7.3L
post #4 of 4 Old 05-13-2013, 02:28 PM Thread Starter
Pulled out the axle shaft completely; all seals are beyond gone, and looks like the outer shaft/spindle has been chewed away from a bad needle bearing.
A seized caliper sure turned into a hell of a lot more!!! :/
So far, I will need new vacuum seal, inner axle seal, and outer shaft.
Did they make two different axles in 99? The outer shaft seems way too small for both 99 hubs I have. And the hubs are the right model...
Then & Now
Matt
'99 F-350 4x4 7.3L
