2001 f350 front axle seals diagram? need help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-09-2013, 04:53 PM Thread Starter
Quoted: 2 Post(s)
I am replacing my axle ujoint on the right side and then moving to the left side. the axle seal that is in the steering knuckle appears to be in ok shape, and the i assume another seal, that goes on the axle where it goes into the tube, its shot. does anyone know what seal is what or anyone have a diagram? i am trying to figure out which seal to replae and which ones i can get by with. btw, got manual lockout hubs now so dont have to worry about vaccum. any help would be good. my ball joints and wheel bearing seem to be good for the time being.
2001 ford ccsb 7.3 auto 6 inch lift, custom bumper, headache rack, ts chip, intake,
Wifes- 2005 CCSB 6 speed, 6.0, all items to bulletproof it.
jrex2506 is offline
post #2 of 5 Old 05-09-2013, 05:07 PM
There are 2 seals on each axle shaft.....the outer one is the vacuum seal for vacuum hubs, the inner seal is just a dust seal. There is 2 more seals located inside the the differential part of the front axle that keep the diff fluid from leaking out. these ones can only be replaced by removing the differential/ring gear assembly. If you are just replacing u-joints and you are using manual hubs i would just reuse the vacuum seals on the end of the axle. Hope that helps
1fastblackz is offline
post #3 of 5 Old 05-09-2013, 05:35 PM Thread Starter
Quoted: 2 Post(s)
ok thanks i kinda figured it out but stil was confused, i may replace or install something to fix the dust seal, axle is rusted some for going to clean it up before reinstalling. i think my inner seals are good.
jrex2506 is offline
post #4 of 5 Old 05-09-2013, 05:45 PM
ZMANN's Avatar
Quoted: 1792 Post(s)
if your inner axle seals were leaking oil would drip out the end of the axle tube assuming the diff had the proper fill
the dust seal keeps rocks out of the tube LOL
the later trucks they came out with an updated seal that abandons the axle shaft mounted seal and now it locates into the axle tube and actually works as it's supposed to
paint the axle shaft after you clean it except the end with the splines
your knuckle seal isn't very critical due to manual hubs
We Miss you Ronnie
6.0 flush pdf
ZMANN is online now
post #5 of 5 Old 05-10-2013, 01:44 PM Thread Starter
Quoted: 2 Post(s)
ya for now i just put everything back together, didnt install new dust seal, calling for lots of rain so that will be a project for another day. however, i got an 05 and just noticed today a binding sound when i turn the wheel full lock to the left and now noticed some oil that appears to be coming out of the axle tube. so got to investagte that. is there any special tools that are needed to replace the inter axle seal in the axle tube?
jrex2506 is offline
