Rear end popping when I let out of throttle - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-07-2013, 05:38 PM Thread Starter
J.Russell's Avatar
When I let out of throttle or getting in it my rear in pops loud any body know what that is? Thanks
Sent from AutoGuide.com App
01 F-350 welding rig
Cold Air, 5" turbo back strait,
Gauges,
DP-Tuner 60t 80e 140,
Foil delete,
CCV Re-Rout,05 headlights,10k's
5 percent all the way around
4" pro comp
J.Russell is offline
post #2 of 10 Old 05-07-2013, 05:48 PM
Redlazer's Avatar
Sounds like it may not be your rearend it sounds like your universal joint is going bad.
early 99 Red F-250 XL SD, 7.3L, 6-speed manual, Extended Cab, Long Bed, 4x4 Off Road, and Reflexxion Cowl Hood, Ion Alloy 183 wheels, 05 headlights with 6000k AC HID kit, and led turn signals, Ford ASI filter w/ zoodad mod and foam sleeve, TS 6 position chip, Auto Meter Z series Boost and EGT gauges, and straight pipe oem exhaust. .
CAROLINA GRAY BOY
Redlazer is offline
post #3 of 10 Old 05-07-2013, 05:49 PM Thread Starter
J.Russell's Avatar
You may be right doesn't it have to pressed off and on
Gauges,
Foil delete,
4" pro comp
post #4 of 10 Old 05-07-2013, 05:51 PM
Redlazer's Avatar
I'm not sure on the super duty. I think they do though.
CAROLINA GRAY BOY
Redlazer is offline
post #5 of 10 Old 05-07-2013, 05:53 PM Thread Starter
J.Russell's Avatar
I shook it and it does have some up and down slack not a whole lot but it has some think that could be it?
Gauges,
Foil delete,
4" pro comp
post #6 of 10 Old 05-07-2013, 05:54 PM
Redlazer's Avatar
I think that is it.
CAROLINA GRAY BOY
Redlazer is offline
post #7 of 10 Old 05-07-2013, 06:00 PM Thread Starter
J.Russell's Avatar
The pinion it's self should have turn back and forth a little shouldn't it? And I noticed my u joint has some slack to
Gauges,
Foil delete,
4" pro comp
post #8 of 10 Old 05-07-2013, 06:03 PM
Redlazer's Avatar
I'm not 100% sure but I think it should. Hopefully Someone else can chime in.
CAROLINA GRAY BOY
Redlazer is offline
post #9 of 10 Old 07-02-2014, 06:33 AM
Tony7's Avatar
I'm not sure if I have the same thing you have but, in my 02 F350 crewcab, basically everytime I pull out from a dead stop/come to a slow stop there is a pop/clunk that seems like its coming from the rearend. I just replaced the pinion bearing in the rear and put a new rear u joint on. Still having an issue with this. It can't be normal for it to do this but I have no idea what it could be.
2002 F350 Super Duty
"Maaa!!!...The meatloaf!!!...We want it now!!!" ~ Chaz
Tony7 is offline
post #10 of 10 Old 07-02-2014, 12:01 PM
Tony7's Avatar
Nvm...I think I actually found the real reason behind my problem
Clunk, Thud, Bump, Double Bump, Spline Grease Job
Tony7 is offline
