Rear end help please - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-07-2013, 03:05 PM Thread Starter
J.Russell's Avatar
I have an 01 F350 my rear end is on its last end I can get a 3/4 ton rear end for cheap can any body tell me if the chunks are interchangeable
Sent from AutoGuide.com App
01 F-350 welding rig
Cold Air, 5" turbo back strait,
Gauges,
DP-Tuner 60t 80e 140,
Foil delete,
CCV Re-Rout,05 headlights,10k's
5 percent all the way around
4" pro comp
J.Russell is offline
post #2 of 12 Old 05-07-2013, 03:20 PM
jesilvas's Avatar
Quoted: 2 Post(s)
If yours is the dually then that's at least a 4.10. F250 max would have been a 3.73.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 12 Old 05-07-2013, 03:25 PM
sooty4545's Avatar
I had to look for one for an E350 and finding one at a reasonable price in good condition is not easy. Every junk yard I spoke to said they were so tuff they either were still in use, the truck was junked with a good rear and that rear is super expensive or the rear was cheap but totally gone for one reason or another. Best bet is probably to find a local yard by you with a F350 like yours in it and go and pull the rear yourself. Mine was actually broke upon delivery because the yard pulled it out and just didn't care about the condition of the axle at all. As far as interchangeability, I was told different things from different people when I was looking, so I cannot really help you there.
2004 f-250 harley davidson, cc short bed, tint, 6 inch lift, 38x15.50 mud grapplers, 20 inch rims, warn hubs, 4 inch straight pipe, sct, pioneer p-3100dvd , 1000 watt amp, autometer gauges, aem brute force intake, python alarm
1948 Studebaker M5 pickup, 169 flat head, three speed, farm truck
1980 Jeep cj-5
1971 VW Karmann ghia, vw 2276 stroker (10.5-1 compression, dual webber 44's)
1965 Honda dream 305
1974 CB360
1971 Honda sl70
1981 Suzuki pe250
sooty4545 is offline
post #4 of 12 Old 05-07-2013, 03:49 PM Thread Starter
J.Russell's Avatar
Would you have any idea on what it would cost to rebuild? What it's doing is when I let out of it it pops and when I get back in it it pops and I'm 6 hours from the house working
Gauges,
Foil delete,
4" pro comp
post #5 of 12 Old 05-07-2013, 04:01 PM
sooty4545's Avatar
I believe your F350 should have the same dana 80 unit as my E350 I was working on. I was looking at between 800-3000 depending on what exactly was wrong for an axle shop to fix it. The shops said without at least pulling the cover off they could not give me a very accurate price. Buying a new, used third member and installing it yourself would probably be cheaper, a third member goes for around 600 used in good condition from what I saw. On a second note, are you sure its the axle not the u-joints?
1980 Jeep cj-5
1974 CB360
1971 Honda sl70
1981 Suzuki pe250
post #6 of 12 Old 05-07-2013, 04:12 PM Thread Starter
J.Russell's Avatar
Positive I changed the pinion seal about 2 months ago and noticed it had some slop in it.. I appreciate all the info and help
Gauges,
Foil delete,
4" pro comp
post #7 of 12 Old 05-07-2013, 04:13 PM Thread Starter
J.Russell's Avatar
I guess mine was a special order cause I climbed under and looked it is a 3.73
Gauges,
Foil delete,
4" pro comp
post #8 of 12 Old 05-07-2013, 04:15 PM
sooty4545's Avatar
No problem, hope I could be of some help. Hope you get it figured out.
1980 Jeep cj-5
1974 CB360
1971 Honda sl70
1981 Suzuki pe250
post #9 of 12 Old 05-07-2013, 05:20 PM
jesilvas's Avatar
Quoted: 2 Post(s)
A DRW 3.73?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #10 of 12 Old 05-07-2013, 05:52 PM Thread Starter
J.Russell's Avatar
A DRW 3.73?
Yes sir
Gauges,
Foil delete,
4" pro comp
