Rotor removal help!! already off the ground - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-07-2013, 09:44 AM Thread Starter
Quoted: 3 Post(s)
Am I missing something?
remove caliper and caliper mount
remove 8 nuts on hub extender assembly
then rotor should come off with some persuasion?
do I need to mess with the 4x4 selctor hub at all?
any help would be appreciated
f350 2000 4x4 DRW
2000 DRW CC 7.3
Exterior: 08 Exterior Clone, 22.5's
Engine Mods: GTP38R WW2, 5 inch exhaust,T500, 6637, TW tunes,DI Up pipes, 6.7 fuel pump fuel system.
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Sound Mods: 7" flip out tv, 3-way speakers all around, 12" sub, 500 watt amp.
Misc:dieselsite coolant filter, max ac assist, BRV, IHD,gauges, CCV
Next up power rear window
campbellflage is offline
post #2 of 6 Old 05-07-2013, 10:42 AM Thread Starter
Quoted: 3 Post(s)
bump .
2000 DRW CC 7.3
post #3 of 6 Old 05-07-2013, 11:15 AM Thread Starter
Quoted: 3 Post(s)
got it... BFH does the trick every time
2000 DRW CC 7.3
post #4 of 6 Old 05-09-2013, 04:23 PM
A torch helps too.
highlandre is offline
post #5 of 6 Old 05-09-2013, 04:42 PM
timmyboy76's Avatar
timmyboy76 is offline
post #6 of 6 Old 05-09-2013, 06:27 PM Thread Starter
Quoted: 3 Post(s)
Thanks all. The dually is different from guzzles page though. I got it done, finished up the rears this afternoon. Awesome upgrade!!
2000 DRW CC 7.3
