2 or all 4 brakes sticking??? Need tech input - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-02-2013, 11:16 AM Thread Starter
Okay, so I'm hoping the end of this story is master cylinder and all my bleeders turn out not to be rusty like the rest of my truck and come loose easily...
Xtra Details not in sig line: Truck is an 4x4 with 4 wheel antilock and cruise control
Symptoms: lately I've noticed that when i come to a stop the truck has stopped rolling freely, almost like the parking brake is lightly set (but it isn't, in fact it's too loose to function) and I sometimes feel resistance when rolling and smell a bit of a burning brake smell. I thought at first it was probably just a sticky caliper pin, however, a few times ago I checked for heat after it happened and it felt like 2 on one side were possibly hot. (I just did rear rotors and am pretty confident I did a good job lubing the pins.) Today it was sticking pretty badly and when i checked, all 4 wheels were hot, like the actual rims got hot to the touch and I could feel heat coming off all 4 rotors. it doesn't happen every single time but seems to be getting more frequent.
I've never had this happen before. I'm guessing this is probably a sticky master cylinder? But I'm also worried it could be signs of a failing anti-lock controller or something else I'm not thinking of. Anyone have a similar experience or good knowledge of this braking system that could give me some input before I just buy the master cylinder and start cursing about how stupid it is to have bleeders that inevitably freeze stuck by the time they need to be used for repairs.
2003' F350 7.3L Lariat Crew-Crab 4x4 6spd Manual Short Bed. 3.73 ratio and that's about all i know... so far.
Motomike777 is offline
post #2 of 13 Old 05-03-2013, 12:50 PM
Todd's 6.0's Avatar
I am having similar problems. About. A month ago the driver rear caliper stuck, then without intervention, started working again. Then on Wednesday the driver front was sticking. That will get some attention this weekend because it got very hot and will need to be taken apart and the hub inspected. Not to mention new rotor and pads. It has been parked ever since.
2005 F250 Lariat CC FX4
Arp head studs
OEM Head gaskets
Bulletproof Diesel EGR cooler
Bulletproof Diesel Oil cooler
Upgraded one piece "STC" fitting
Upgraded Standpipes and Dummies
Upgraded turbo oil lines
Blue Spring
Cat Delete
Coolant filter
Rerouted Closed Crankcase Vent with catch can
Edge Insight CTS for gauges
Todd's 6.0 is offline
post #3 of 13 Old 05-26-2013, 05:05 PM
Jamessims's Avatar
Easy fix take the caliper off and pull the sliding pins and clean them up and reinstall them with anti-seize high temp also apply a small amount where the end of the pads sit in alignment. Did mine a month back worked like a charm...
Jamessims is offline
post #4 of 13 Old 07-24-2013, 02:30 PM Thread Starter
This turned out to actually be the master cylinder. Bleeding the system took a long time even though I pre-bled the MC on the bench, it still took a while to bleed out at the connections once I installed it. Thankfully, i didn't end up having to bleed it at the wheels... until my rear brake lines failed a few weeks later....
post #5 of 13 Old 07-26-2013, 02:39 PM
sofmech's Avatar
I had this same problem however mine started out with the brake booster leaking bad. I replaced that and the MC at the same time. Shortly after that I thought it was just the right rear sticking. I replaced the caliper, pads and rotors....still getting hot. Replaced the right rear brake line.... still hot. The hubs seemed to be getting really hot so I replaced the rear hubs and bearings. All 4 brakes are dragging and getting hot. I took put the 60 amp fuse for the ABS module.......still hot. I'm at a total loss now. Anyone think I could have gotten a bad MC? Thats the only thing I can think of. I bench bled the new one, could it need to be bled again? I bled all 4 wheel until new fluid came out of each. Trying not to take it to a shop but I'm almost at that point, help, please!
sofmech is offline
post #6 of 13 Old 07-26-2013, 03:18 PM
STANGMAN893's Avatar
I have the same problem with my 02 Excursion especially stop and go. I think my parking brake shoes may be the problem. The ford backing plates are known for going bad where the hold down pins are. My friend had to take his parking brake shoes out of his 03 in the parking lot while at the Jersey Shore. When I worked at the dealer we stocked 2 sets of each side and 2 sets of rear calipers. Not looking forward to this deal with the lift and 35's.
STANGMAN893 is offline
post #7 of 13 Old 07-26-2013, 03:27 PM
Quoted: 862 Post(s)
Feedback Score: 3 reviews
More than likely you got a bad replacement MC. Where did u buy your replacement?
Corey@CNCFAB is offline
post #8 of 13 Old 07-28-2013, 12:17 PM Thread Starter
This is probably a dumb thing, but are you sure you didn't over-fill the new MC? overfilling can cause brakes to stick as well. If you're over the full mark, try drawing a little fluid out and see if that helps.
post #9 of 13 Old 07-28-2013, 12:31 PM
cuzzdogg's Avatar
My driver side front caliper locked up & released several times on a 4 hour round trip. I changed it out when i got home. Under the advice of a shade tree I changed out the lead hose also. He said there has been many cases where the hose tears on the inside and causes a 'check valve' effect.
Sent from AutoGuide.com App
cuzzdogg is offline
post #10 of 13 Old 01-11-2016, 02:18 PM
Anybody come up with the solution to this problem? My truck sat for about three weeks. Took it down the road and the ps front brake hung up and almost stopped the truck. Took all apart, cleaned, and bled that caliper at the bleeder. Saw nothing obvious. I then pumped brakes back up. Then disconnected rubber hose at metal line connection and forced fluid back thru line and it went without any restrictions. Nothing out of the normal that I found there either. Took it for a drive today and the front ps brake and both rear brakes dragged so bad they started smoking. Got it pulled over and cracked both lines on master cylinder and that seemed to relieve them. Not 100% sure this did though. Drove it home without touching the brakes in about 15 miles and it drove freely. No heat at all in any of the brakes. I have read about flushing the power steering system to help the brake booster and will do this soon. Truck is a 2002 f350 quadcab diesel.
jake126 is offline
