Driveshaft help!!!!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-01-2013, 07:56 AM Thread Starter
I took the The front driveshaft out because it stays locked in 4 wheel drive and while the driveshaft is out the front spindle is still spinning. What is causing that? How do I make it stop? Also, the mechanic said the module on top of the transfer case is bad. What is it called and how much are they?? Driveshaft help!!!!!-imageuploadedbyag-free1367420196.468581.jpg
Galileo is offline
post #2 of 3 Old 05-01-2013, 02:17 PM
JSchuricht's Avatar
If your front axle is spinning without the drive shaft, you have a hub locked. Jack up the front axle and spin each tire individually. Whichever one makes the pinion spin is locked. Either you have the lockout turned to lock or it's stuck in that position.
There is no module on top of the transfer case. If you have a manual shift, there is one sensor. If you have a electronic transfer case there is a motor and a position sensor bolted to the side of the transfer case. Did your mechanic pull any codes indicating a transfer case issue or is it just not working? You can check if it's stuck in 4x4 by crawling underneath and spinning the front flange. If you put it in 4x4 it won't spin, 2x4 will spin.
JSchuricht is offline
post #3 of 3 Old 05-06-2013, 06:10 AM Thread Starter
The truck isn't throwing codes. How do I take the hub out and check if the grease and everything in the hub is okay?
Galileo is offline
