4x4 wont engage - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-14-2013, 10:34 AM Thread Starter
4x4 wont engage
my 4x4 wont engage on my 2001 F350, the light comes on on the dash but it doesn't actually engage.... Any ideas????
nellyd is offline
post #2 of 4 Old 04-14-2013, 10:57 AM
rocktamer's Avatar
I would guess that its engaging the front differential but not the hubs, does it work if you manually lock the front hubs?
You have a vaccum leak would be my guess. One of the vaccum hoses is cracked or disconnected, or one of the hub seals is bad. They make a vaccum system tester that checks for leaks but I would visually inspect the system from the vaccum pump to the hubs. Vaccum leaks are a PITA and a lot of people end up just replacing all the hoses.
Personally I just manually lock my hubs though.
1999 F250 XLT 4X4
rocktamer is offline
post #3 of 4 Old 04-14-2013, 11:24 AM
TGauger's Avatar
I would agree with the above. I had a similar issue where my transfer case would engage but the auto hubs weren't. I had to get out and manually lock the hubs. My vacuum leak was in the seal of the hubs.
05 F-350 CCLB, Harley Davidson Edition
TGauger is offline
post #4 of 4 Old 04-14-2013, 02:11 PM Thread Starter
They do work manually, so i will check all the vacuum lines going to the hubs thx....
nellyd is offline
