Driveline vibration around 50 mph - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-01-2013, 08:12 AM Thread Starter
What a month for truck issues.
My truck is a 99f250 7.3, 4x4 auto.
My truck in the last few weeks has developed a driveline issue. It starts hard, won't start if not plugged in, is very sluggish when cold and the tranny is not wanting to shift at times. I have developed an intermittent vibration that comes and goes. It feels very much like driveshaft vibration but the driveshafts feel fine with NO slop in them. Almost concerns me there is no slop at all. I haven't got anything else that doesn't give a little. The driveshaft carrier bearing has some movement up and down but I was told at the dealership that was normal.
Same dealership has come to the conclusion that my injectors are bad via a buzz test. Recommending replacing them. At 290,000 miles I don't doubt it but I am concerned about the driveline vibes. There doesn't seem to be any play anywhere.
The vibration is in the seat, not the steering wheel and there is a bit of rotational noise accompanying it that is to the rear. It really feels like a driveshaft. Ia am transmission paranoid because I still have the original but the dealership seemed to think the not shifting is due to a power issue and there is definitely less power than in the past.
Any assistance would be appreciated. Facing the injectors, I am concerned about money, but I have to get the touch reliable.
1999 F-250 4X4 Crew cab Lariat short bed junk hauler. Truck is used for daily hauling of steel. 26000 lbs or less. No performance mods other than larger exaust. Wanted this truck since it came out in 99.
WHAT it only took me 7 years to buy it!!
Chevrolet 6.2 convert so as you can bet I am thrilled with the power of the Powerstroke!
Rio_Grande is offline
post #2 of 5 Old 04-02-2013, 06:13 PM Thread Starter
Did I ask a really dumb question and nobody wants to tell me?
post #3 of 5 Old 04-06-2013, 10:18 AM
I have the same problem. My rear shocks were shot. I replaced them and it helped . But it didn't go away completly. Now I just found one of my rear leafs is broken so I'm thinking that's where its comming from. Might b worth checkin ur springs for cracks or ur shocks.ill let ya kno if that fixes it.
early 99 F-350 cc, lb, 4x4
tony wildmann 6 pos.
4 in turbo back to a pair of 6" black chrome miter cuts
foil delete, stage 3 cold air intake
6 in lift with 37"s
238/100 sticks
not much but its a start
gibbogr is offline
post #4 of 5 Old 04-06-2013, 11:48 AM Thread Starter
I will check. Today while driving from a stop at the house it started, stayed that way for 5 miles till the first stop light. I stop, pull away and I don't feel it again until later in the day after sitting a while it did it again. I pulled off the road and stopped. Pulled back out and it was gone rest of the way home. It is a fast vibration.
post #5 of 5 Old 05-22-2013, 07:10 AM
johndeeregarner's Avatar
Check you icp sensor. If it goes bad it will send a bad signal to the computer and therefore the injectors won't fire properly.
johndeeregarner is offline
