Front driveshaft binding - Ford Powerstroke Diesel Forum
post #1 of 21 Old 03-25-2013, 10:23 AM Thread Starter
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Hey guys i have my truck in the 4x4 shop and they are saying the angle of my drive shaft is too big so my u joints are binding when my suspension is stretching.
Beyond tilting the front axle which he said screws up the steering what are some options to stop this?
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #2 of 21 Old 03-25-2013, 12:04 PM
Macon's Avatar
Not too many.
Take out the front drive shaft and don't worry about it
Spin the diff on the axles to reposition
Lower truck.
Rear is a lot easier, though you still have to worry about seals. The front is where all the camber and toe and all that happy stuff happens, and simply rotating the axle will cause issues. Like steering in to the ground instead of sideways. But, actually rotating the diff on the axles will change the drive shaft angles, while maintaining camber and alignment. A good 4x4 shop can do it, but I have no idea what they charge.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 21 Old 03-25-2013, 12:09 PM
Matty8734's Avatar
Quoted: 123 Post(s)
Most 4x4 fab shops will a "cut-n-turn" where they set the pinion angle correct then cut off the steering knuckles and re weld them to the axle tubes after setting the correct caster angle. I had it done on a '66 scout and my shop shop charged $600.
'04 ExCab LB
Studded, Tuned, and more
Matty8734 is offline
post #4 of 21 Old 03-25-2013, 12:11 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Originally Posted by Macon View Post
Not too many.
Lower truck.
So they actually can rotate the pumpkin independent of everything else? I never knew that
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #5 of 21 Old 03-25-2013, 12:14 PM
Macon's Avatar
That's definitely one way to do it. We always just locked the hubs, heated up the diff, and rotated via yoke leverage. With no "standard" angles to adjust to, it was all done with that redneck eye of "Yep, looks good". Test drive, then weld tubes in place. edit to add: It also wasn't done in any sort of professional capacity. Just back yard fixes. If a professional shop does it in a different manner, I would side with their way of doing it.
2002 F250 CCSB 4x4
Macon is offline
post #6 of 21 Old 03-25-2013, 12:15 PM
Matty8734's Avatar
Quoted: 123 Post(s)
Yes, but it requires a competent shop to do it! most "box" store places like 4wparts and such don't do custom stuff to make the lifts work right.
'04 ExCab LB
post #7 of 21 Old 03-25-2013, 12:18 PM
Matty8734's Avatar
Quoted: 123 Post(s)
This method does work, but wouldn't recommend it on something that you daily drive or have to trust to keep you and other people safe. I did it on a trail rig that was trailerd place to place
'04 ExCab LB
post #8 of 21 Old 03-25-2013, 12:19 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
Mine shop definitely isnt a box store they specialize in huge lifts so they oughta be able to do that i think
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
post #9 of 21 Old 03-25-2013, 12:25 PM
Macon's Avatar
Yeah, I edited my post to add in what kind of fix it was. Mine was a dd, but most of the ones done were primarily trailer queens.
I hate to talk them down, but if they are saying there's nothing they can do to fix your problem, they are not a 4x4 shop. They're a lift kit installer shop. They might be great guys, but bolting on parts is a lot different than fab'ing components.
2002 F250 CCSB 4x4
Macon is offline
post #10 of 21 Old 03-25-2013, 12:35 PM Thread Starter
Chapter Director
Quoted: 5 Post(s)
They didnt say they couldnt, they arent just a lift kit installer, they are a true 4x4 shop its two brothers and a couple other guys in a shop and they have several highly custom lifted trucks sitting out back. I trust them they know what they are doing, he never said they couldnt he just told me it will need to be fixed in the future before i do any more 4x4ing so i was getting ideas how.
Is there anyway to turn the t-case so its angled lower?
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
5:13 Gears
Standard 7.3 mods
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
