Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Drivetrain Problems
Old 01-24-2008, 08:58 AM
pilotohio3 pilotohio3 is offline
Parking Brake Cable
Hey all,
I was curious if any of you knew how to replace a park brake cable? Mine broke the other day and im in the process of getting a new one.
The truck is a 2000 F-350 DRW, 6 speed, Supercab, and in case you are like Ford, Yes, it is the rear cable, seeing as that is where my park brake is located.
I am somewhat mechanically inclined, so I dont need the entirely simple explanation, but any tips would help. Thanks
Old 01-24-2008, 12:42 PM
adfields adfields is offline
It's the rear cable? The front is the one that always snaps at the point it hooks to the peddle, the little ball snaps off. If it's the rear you pull the drum off to un-clip the inner from the arm and the otter from the backing plate. The back and middle cables are very easy, the front is another story all together.
Old 01-24-2008, 12:44 PM
REDPOWERSMOKER REDPOWERSMOKER is offline
WE ARE DOOMED
Tournaments Won: 1
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
OR IS IT THE ONE THAT CONNECTS UNDER THE DRIVERS DOOR AND GOES TO THE REAR AND CONNECTS TO THE TWO INDIVIDUAL CABLES IN THE BACK IF ITS THAT ONE THE FORD HOUSE HERE ACCIDENTALLY BROKE MINE AND THEY SAID THE CABLE IS ABOUT 40.00
Old 01-25-2008, 10:32 AM
Well, the pedal went down and has no tension on it now, but yes, it ran under the drivers door to a point in the rear, and I did not see that point when it broke. So it is my pedal, yes, but I know the cable ran to the rear. And Ford said something around $40 here, also, but im not taking my truck to them anymore. It always leaves with more problems than it went in with.
Old 01-25-2008, 10:44 AM
WE ARE DOOMED
Tournaments Won: 1
EXACTLY I TOOK MINE IN FOR THEM TO REPLACE MY PEDAL AND IT CAME OUT WITH THE BROKEN CABLE THATS WHY I WONT USE THIS FORD HOUSE ANYMORE I GO TO THE NEXT NEAREST ONE
Old 01-25-2008, 04:11 PM
It has 4 cables on it; from the peddle to about the trans cross member, from the trans cross member to just in front of the spring hanger, and from that point one to each wheel.
If the peddle went to the floor odds are it's the front one, at the peddle it's self. First thing you need to do is find the broken point so you get the piece you need to fix it.
The peddle is held in with 3 bolts, drop it down and look from the back side to see if thats the broken point. Thats my bet, I used to replace that one every 3 months on a 99 F550 wrecker I had. I put a micro lock on it when the warranty ran out and I had to replace it myself.
