Need help bad! Stuck side road. - Ford Powerstroke Diesel Forum
post #1 of 12 Old 03-01-2013, 08:54 PM Thread Starter
I was driving the truck, then it got a dead pedal. I called the guy and he said check fuse 45. It was blown, I replaced it. Drive about 15 miles and then the tranny feels like it shifts up down up down then no pedal.
I pull over and 1,2 and reverse work but not drive. Then a few minutes it does. I drive 280 miles and the tranny just feels like its Doing the same thing and then O/D light flashes on and off and won't stop.
I have front drive shaft off because it won't come out of 4wd. The fuse looks almost burnt again. It's a 10 fuse and that's what I put there. What else could be going wrong??? I'm stuck. Literally.
This is my first ford and a brand new tranny and motor has 67k miles. I know nothing about fords but I am a little mechanically inclined.
2002 7.3l huge lift, tires etc.
Galileo is offline
post #2 of 12 Old 03-01-2013, 08:58 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Pull the steering column cover off and see if the wires that come out of your gear shift handle are chafed or one is broken.
dhanna6powerstroke is offline
post #3 of 12 Old 03-01-2013, 09:20 PM
Mod Newbie
Quoted: 20 Post(s)
post #4 of 12 Old 03-02-2013, 05:36 AM Thread Starter
It says that URL is invalid
Galileo is offline
post #5 of 12 Old 03-02-2013, 05:39 AM
Mod Newbie
Quoted: 20 Post(s)
That's weird. When I click on it, it downloads the PDF.
post #6 of 12 Old 03-02-2013, 05:49 AM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
maybe his phone wont do a pdf
Mild build 07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx custom tuned, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Lighting, No Limit S2 Intake, Tinted, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, 4.10 Yukon's with electric lockers, 37/13.50/22 Toyo MT, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, LED heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
MyTractorsSexy is offline
post #7 of 12 Old 03-02-2013, 05:53 AM
Mod Newbie
Quoted: 20 Post(s)
Type into google "transmission shifter lever chafe repair" and it will be the first thing that comes up.
post #8 of 12 Old 03-02-2013, 06:14 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
If you can't get that .pdf (it IS the Best doc on the subject) you could try the page Here -> https://b7445ba3-a-62cb3a1a-s-sites....attredirects=0
Also, there's this Here -> 99-03 OD wire fix
NoRalPh is offline
post #9 of 12 Old 03-03-2013, 05:57 AM
My guess is your wires in the overdrive toggle switch are touching together causing shorts. Same problem with mine but tranny still worked correctly, had the small wires in the toggle switch touch and killed all dash controls and my throttle. Little electrical tape and a new fuse saved me.
Mission7.3 is offline
post #10 of 12 Old 03-03-2013, 07:42 AM Thread Starter
Mission, how do I fix that? This is my first ford and I have no idea what and where parts are. I have put it in gear before and it has killed all lights in dash and a dead pedal before to and blown fuse
Galileo is offline
