Popping noise in the front end!
Hello everyone,
I own a 2000 f250 ext cab long bed 4x4 with the 7.3 ltr. I was having some popping noises comming from the front of the truck it feels like it under my feet on the driverside. I replaced upper and lower ball joints, hub bearing assemblies on both sides and sway bar bushings and end links, also tightened up the body mount bolts. Everything seemed to help alot but still get a slight popping noise driving straight semi bumpy road. Any suggestions? Thank you! |
I have the same thing happening.... I think its something with my leaf springs now. I replaced shocks new steering stabilizer. I see you replaced all of that and it still does it...
check the track bar and its mounts, they like to make noise if anything is loose
Check the brackets on the tie rod and drag link, mine was doing that and thats what it was, there is a bracket on i think it's the drag link and it catches on i believe the tie rod or another bracket on the tie rod. I had the problem for years untill i happened to be under the truck and the tires were turned at just the right angle to see that they could kinda catch. I ground a little off the bracket and no poping since.
