Still got problems... - Ford Powerstroke Diesel Forum
Old 01-23-2013, 08:58 AM
Hi all.
I put a new vacuum seal/bearing behind the hub, replaced the hub on my truck (Details in sig) and the beariing went bad again... I got mad, pulled the hub off agian, pulled the spindle shaft and axle out, blocked off the axle with a tennis and tshirt and put the bub back on with no axle. I got it all back together and test drove it. It still has a vibration in the axle that feels like its grinding.... Im at my wits end. Im about to tear down the entire axle and replace every single component in it! Is it ok to drive it with no axle in it?
