Need help with rear hub seal. - Ford Powerstroke Diesel Forum
Old 01-12-2013, 12:24 PM
I'm trying to replace the seal. The dealer did a vin bomb and gave me P:N 2C3Z-1177-AB. This is the wrong seal for my axle.
I tryed to install it, but it won't tighten up all the way. It still needs a 1/4" to tighten all the way. When I bolted the brake caliper on it was tight against the disk and would not spin.
The old seal has a 1/4" off set, inside that the new does not have. The dealer says it the right one. I stopped by a few part stores they all had the same seal as the dealer.
The dealer said its for a 10.5 axle.
Could I have 10.25?
How can I tell?
Does anyone know a different number?
01 f250 4x4 cc 7.3
10.25 axle?
Old 01-12-2013, 12:46 PM
Pics.
Old seal has the dent
Axle tube.
Need help with rear hub seal.-cimg1642.jpg   Need help with rear hub seal.-cimg1643.jpg
Old 01-14-2013, 05:19 PM
Update: Turns out it is the right seal. The old seals inner metal band was still on the axle tube. Got the old one off and every thing fit.
