02 f250 auto/4x4 98k miles. about a week ago started hearing chirping under the truck. i assumed the cross bearings/u joints whatever you want to call them, or the support bearing were on their way out on the rear driveshaft.
today jacked the rearend up, tranny in neutral, i spun the tires/driveshaft and couldnt get the sound to occur. there were no visible signs that they were shot that i could see, no play in all 3 joints and no play in the support bearing. I'm thinking maybe they need a load/more speed on them in order for the sound to occur? any help/ideas are appreciated..thanks
ok replaced all 3 1410 joints with moog joints and also the support bearing with a timken bearing..in and out no problems back together no problems marked everything...didn't solve my squeaking noise, but all the u joints were shot anyhow truck has close to 100k on it so not a total waste.
however, i now have a vibration above 35 mph that was never there, im guessing i could have been off by one spline on the yoke though i did mark them pretty close but you never know..could anything else have thrown it off? bearing pressed out and back in no problems i wasn't banging on anything to throw off the balance i wouldn't think.
i might try tomorrow to pull the yoke back off and shift it over one spline see if it fixes it otherwise ill suck it up and take it to a shop to get rebalanced.
can anyone think of anything i may have overlooked?
took the yoke back off tonight and moved it over one spline to where i thought it could have gone..still have vibrations but they are a alot better which makes me believe this is where the yoke should have gone and that nothing i did was wrong, shaft just needs to be rebalanced....
anyone know how they balance driveshafts? they leave them on the car/truck or they take them off and mount them to a machine?
flange that bolts up to the rear axle was bent..must have done it pressing the old bearings out and didn't notice it..all is well now.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
