transfer case question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 01-01-2013, 10:52 PM Thread Starter
importedaze300's Avatar
will a tc off a 5r100 fit on the 4r100 i do recall reading in a magazine that there was a guy who swapped out the 5r100 for the 4r100 i am looking to learn more on this i have the option of getting a 4x4 rolling chassis off an 04 and before going forward with it i just wanna make sure i can use it and if it doesnt i know i can still uses the front axle and mounts for the 2wd 4wd swap thank you guys in advance for your input
importedaze300 is offline
post #2 of 11 Old 01-02-2013, 05:45 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
No it will not work, we have a hybrid Tq converter that will fit and doesn't require any mods.
CT Performance, Inc. is offline
post #3 of 11 Old 01-02-2013, 06:40 AM
Quoted: 184 Post(s)
Feedback Score: 3 reviews
Ooops, I misunderstood what you were doing...
NoRalPh is offline
post #4 of 11 Old 01-02-2013, 08:31 AM Thread Starter
i appologize i just wanna know if the transfer case is swappable to the 4r100
post #5 of 11 Old 01-16-2013, 05:31 AM
Supercharger07's Avatar
yes and no. The 5r110 trans has a bigger output shaft. which means the transfer case off a 5r110 has a bigger input sleeve and will just slide over the 4r100 trans output shaft, you need the sun gear out of a transfer case from a 4r100 or a whole planetary.
1999
F-350 4X4 7.3L Auto Dually Crew cab long box, Banks CAI, Zoodad mod, 4" Straight pipe, TW Chip, GlowShift Gauges,
2001
F-250 4X4 7.3L Auto Crew Cab Short Box 4" lift 35's Mods Coming
Supercharger07 is offline
post #6 of 11 Old 01-22-2013, 01:27 PM
Not intending to high jack thread, but was looking to see if question has been asked before.
I have a lead on a '04 F250 6.0 transfer case and was wondering if I can swap it into my '02 F250 7.3? I don't know the model numbers of each to give, but it sounds possible and if they are different, it could be a change or swap in the output shafts? Is that correct?
Thanks!
82332 is offline
post #7 of 11 Old 01-22-2013, 08:11 PM Thread Starter
thank you SUPERCHARGER.
how about swapping the output shaft to the 5r100 would that work or would all the internals in the trans have to be changed as well
post #8 of 11 Old 01-23-2013, 08:11 AM
82332- it is possible with a sun gear from a 99-03 transfer case. Swap them out and it should fit!
Imported- I haven't been that far into a transmission to tell you for sure if you can swap output shafts. Sorry bud.
1999
2001
post #9 of 11 Old 01-23-2013, 08:50 PM Thread Starter
hey it is all good but thanks for the info it did help and different things to look at
post #10 of 11 Old 01-24-2013, 05:22 PM
[QUOTE=Supercharger07;3701906]82332- it is possible with a sun gear from a 99-03 transfer case. Swap them out and it should fit!
Thanks Supercharger07.
82332 is offline
