Too much play?
I recently purchased a 2000 F350. There is a slight grinding sound coming from the front driver's hub. I took the locking hub off today and it seemed super-loose when I spun it around in my hand - making a rattling noise as it spun. I thought that I had found the problem. Then, I went to move the axle around and saw this:
I am not super familiar with these trucks, but that seems excessive. I am guessing the needle bearing is gone? I did some searching and saw that these trucks have some play, but this seems much. Thoughts/advice would be greatly appreciated. Thanks in advance. |
Well put your wheel back on your truck, and see if you can ( from top to bottom ) push the wheel n tire back and forth, if so. More than likely you have a bad wheel bearing. Not hard to change out but the price for one isnt that cheap.
Looks perfectly normal to me.....
I would check the needles if your noise is coming from that side but, the movement your see in the vid is actually the axle (look at the other side of the knuckle, where the U-Joint is) moving around because there's no support for it at the end of the diff tube. Once you remove the locking hub you take the support away it usually has. There's a surprising amount of movement in our front axles, but most of it's been there since it was new
I tried breaking it down some more, but the dang rotor is frozen in place. Called it quits for today. Try again tomorrow. |
You're not thinking of it right, the twin ball bearings that the wheel turns on has nothing to do with the stub axle. You could take it out and still drive around. The needles are only there to support the stub axle when the lock-out is Free and the hub is turning while the axle is not (that's the definitive test for a bad needle, LOCK the hub, those brgs aren't turning, if the noise goes away - it Was the needles).
So they're really two separate things, the wheel brgs and the axle bgrs... |
Ok. That makes sense. Thanks.
Also, the sound was there regardless of the hubs being locked or not. So the needle bearings can be replaced without replacing the whole hub assembly, correct? Last edited by 69Bronc; 12-29-2012 at 04:38 PM. |
They can, here's a good link with all the info -> Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Ok, so I pulled the hub assemblies from both sides. Sort of expecting to see some type of carnage. The grinding sound wasn't very loud, but it was definitely noticeable. Anyway, everything looked pretty good. Axle stubs look fine. The needle bearings look a little worn, but nothing major.
One question I have - how hard should it be to spin these hub assemblies by hand? Both of them were fairly difficult to spin. The one on the passenger's side made a bit of noise when spinning it by hand, also. Should these units spin fairly freely? Thanks again in advance. |
