bad tps? help - Ford Powerstroke Diesel Forum
Old 11-13-2012, 09:00 AM
Angry bad tps? help
We have a 99, build date 10/98, 7.3 auto. Started it up the other day and drove it for 5 min and then stopped to pick up some things at the shop. Got back in the truck, we let it idle, and it had no accelerator petal. I unplugged the tps and plugged it back in, still nothing. Also no engine light. Any ideas? Tps is $65 but if i plug it in i cant return it.
Also the obdII port is dead. I plugged my scanner in and it would even power up the scanner?
Thanks for the help!!
Old 11-13-2012, 11:11 AM
First, check the fuses. Sounds like something is blown maybe...
Old 11-19-2012, 12:50 PM
Thanks, i dont know why i didnt check the fuses. It was a fuse, #19 10A fuse. And it keeps blowing. I think it blows when i put in in D or R ( auto).
Any ideas?
thanks
Old 11-19-2012, 01:12 PM
Yes, your OD sw wires are shorting under the column cover (very common) and you need to get in there and reinsulate them
99-03 OD wire fix (this applies to you too, the fuse was moved to pos #45 in newer trucks)
Old 11-19-2012, 02:56 PM
Oh sweet. Thanks a bunch man. I would have been searching for hours! Once again the org saves the day. Ill tear into it tomorrow and let you know if thats it.
Thanks
Old 11-21-2012, 03:00 PM
Took it apart and sure enough there was a little slit in the wire. Truck runs great now! Thanks
