clanking in the frontend - Ford Powerstroke Diesel Forum
Old 11-02-2012, 08:50 AM
I've noticed a clanking in the front end while driving on bumpy roads. It sounds like chains clanking or washers banging together. There was a lift on the truck before I bought it and I thought that they might not have tightened everything back down but all seems to be tight. I have all brand new ball joints and just replaced shocks with bilstein 4600s. I can't seem to see anything that is not tight like a bolt or a washer that would be jingling. Also replaced rotors and pads and nothing loose there. I have actually heard other super dutys do this while passing by me.
Old 11-02-2012, 09:35 AM
Check your sway bar bushings.. those usually make more of a "thunk" sound, but could still be the culprit.. also check your sway bar end links (i think that's the name), if nothing can be found there, check your leaf spring bushings.. I know those are some common problems, I had a similar issue a while back and turned out mine was a sway bar bushing..
Old 11-02-2012, 09:50 AM
swaybar endlinks were the first thing that was done when I got it because they were junk sway bar bushings were ok. I didn't check the leaf spring bushings how hard are they to do.
Old 11-02-2012, 10:01 AM
If it is the leaf spring bushings would you go back with factory or aftermarket?
Old 11-02-2012, 10:43 AM
Idk about changing it. I've never had to do it. As far as brand, I'd either look into MOOG or OEM.
Sent from my DROIDX using AutoGuide.Com Free App
Old 11-02-2012, 11:22 AM
I don't know of anything else because just driving it doesn't do it but when you go over multiple bumps it starts jingling like a damn bell, it would be good if it was the leaf spring bushings.
Old 11-02-2012, 04:15 PM
My shock bushings are shot on the back, and if I hit a speed bump, I get a definitive thump. You may be looking at the right area.
Old 11-02-2012, 05:34 PM
I guess i would need to jack it up and try to move stuff around I have already tried this but nothing stands out.
Old 11-02-2012, 05:40 PM
Get some buddies and beer. (Dont jack it up) Have them bounce the truck while you're watching the leaf spring bushings. Lol
Old 11-02-2012, 05:51 PM
beer and buddies sounds like the best way to be productive at least if we don't find anything we can drink more beer. I am suprised nobody has had similar problems. One other thing I just thought about was when they did my ball joints they left the dust rings out of the inner axles do you think what I am hearing is coming from in there that is usually sealed up by the rings. They are still there they just aren't pushed in where they're supposed to be.
