sometimes wont start.... - Ford Powerstroke Diesel Forum
Old 10-25-2012, 06:12 PM
"99" SD250 with 340K on it. Once in awhile when I turn the key and wait for the wts light then crank the motor over I hear a slight clicking sound from the dash about where the WTS light in on the instrument panel. The motor turns over fine and has good batteries and such but it will not start at all. Repaeat steps until it doesn't give that clicking noise when cranking the motor and then it starts just fine. Any ideas?
Old 11-09-2012, 02:04 PM
not sure what it is but im having the same problem...
Old 11-09-2012, 02:12 PM
Check voltage drop at starter relay as well as voltage at starter solenoid.
Old 11-09-2012, 02:13 PM
do this while someone is holding key in start position...sounds like a bad relay or solenoid
