front axle issue
got under the truck and found a bad u joint on my front passenger side, and the axle shaft .. well it moves from top to bottom in the tube.. i've already done hubs and ball joints, so i'm familiar with disassembly, but i don't remember a bearing being in the tube... ? am i just spacing out? or was there one that i have now lost.. if so .. what's the part number for said bearing?
thanks |
thanks for clearing up my brainfart. you wouldn't happen to have part numbers for the NEW style inner (axle end) and outer (hub) dust seal and needle bearing set. from what i remember, besides a ujoint, that's all i should need for this little project.. i don't need the vacuum oring, since i'm manual hubbed..
Just noticed your sig... I have a '70 800A.. doesn't get any better |
![]() i pulled my axle shaft this morning so i could use the truck till all my parts came in.. my needle bearings were nonexistant... my seals are finished and my ujoint is.. of course crapped out.. seals are on order, u joint is sitting at napa a mile from my house, but i'm not sure about the needle bearing.. what's it called? |
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page |
The needele bearing is easy to change napa part number B2110
will be doing this shortly also, as my axle shafts have more than a little play. i am interested to see how bad those needle bearings are as i havent looked at them in the 42k that i have driven the truck. she has 242k on her...
