Dana 60 Carrier Help
Any tips for get the carrier out. I'm changing the axle shaft seals out and need help getting it out.
Thanks 2002 f 250 7.3 |
Easiest way is to pull the caps, stick a rag between the ring and pinion and turn the pinion. The rag will get torn up and you will need to make sure the carrier doesn't drop to the ground.
