Front Caliper Bracket - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-15-2012, 03:45 PM Thread Starter
deere4440's Avatar
I'm replaceing the brakes on my truck cause the slide pins froze and wouldn't come out. Ordered new rotors, calipers and new bracket. Well i also had a lot of play in the front unit bearing, so i replaced both of them. Well now when i put everything back together, the rotor isn't centered in the bracket, it doesn't rub until i but the brake pad clip on, then it rubs hard aganist the rotor?? Any ideas guys?? I'm at a loss....
2002 F-350 CC SB 7.3
MBRP 4 in straight pipe
AIS Intake
Foil Delete
Factory Tech Valve Body
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
deere4440 is offline
post #2 of 4 Old 08-15-2012, 03:53 PM Thread Starter
deere4440's Avatar
AIS Intake
Foil Delete
203 Thermostat
Fog Light Mod
6k HID's from DDM
TOTALED!! 1/6/2009
2003 F-250, 7.3 FX4
post #3 of 4 Old 08-15-2012, 05:24 PM
Macon's Avatar
Can't really tell from the pics, but did you put the brake pads back on?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 4 Old 08-15-2012, 05:25 PM
That is a "early" 99 rotor, on a "late" 99 hub assembly...
the early 99 trucks had shallow hubs, and shallow rotors, the late 99 had wider hubs and deeper rotors
that is why the rotor is rubbing the "outer edge" of the bracket
the trav is offline
