hub Bearing
Can you use a abs hub bearing on a truck that has non abs wheel hub. I know there are some differences between The two hubs.
Sure can. Same exact bearing. Just tie the sensor wiring out of the way or cut it off
Gives you a greasing port also just make sure it's sealed when not being used to grease
you can sell the ABS sensor to someone |
I dont think the ABS sensors in the 99-03 bearings are removable. Not 100% on that though
Hmm I can't say for sure on that but I know someone on hear used a ABS for a Non ABS and used the port and installed the permanent Zerk ??
so non ABS would have to Be a 99/03 I think ? |
Its a 99-03 truck.
Front ABS is optional on them |
right // but ABS was standard for the later years that I know of so I bet it's removable ,, if it's a Timken
guess We will see ,, and the ABS was cheaper for some reason when the other poster did his greasable conversion |
This is the Info I got printed out on Timken hubs.
$265 Non ABS Hub $295 ABS Hub part # : 515021 SP580205 ABS Sensor Included: Yes Yes ABS Tone Ring: Installed Not Included Tone Ring Tooth Count: 44 Flange Bolt Count: 4 3 Flange Bolt Size: M14x1.5 M12x1.75 Hub Assembly Design: Non-Driven Driven Lug stud/bolt count: 5 5 Package Contents: Hub Unit Assembly Bearing Module Spline Count: 55 30 Wheel Stud Size: M12x1.5 M12*1.5 My truck is a 2000 w/o ABS in front Guy has one he is selling in the classified section here is his ad. I just want to make sure his will work on my truck. http://www.powerstroke.org/forum/per...03-04-new.html |
Well everything was in its own column. Difference shown are the two hubs.
when i clicked on it in my email it was in it's own column and atleast one bearing has to be the wrong part
ABS had no tone ring ? and was a 3 flange non ABS was a 4 flange with a tone ring lol Last edited by ZMANN; 06-02-2012 at 08:14 AM. |
