Rear axle internals exploded!!!! Question??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-21-2012, 05:33 PM Thread Starter
Valvejob's Avatar
Hey so I drove 5 hours from home to fix an aircraft for the company I work for on Thursday last week. Right when I got there my rear axle internals exploded(30 miles out), its a complete remove and replace at this point(internals that is). So a rented a car to come back.
My company was nice enough for me to fly co-pilot to the location of my broke down truck to fix and drive it back......
I cant fix it out there of course....so heres my question!
Can I unhook the rear driveshaft, put it in four wheel drive, lock the hubs, and ''limp'' it home? When theres no torque to my rear axle, it seemed to be noise free and theres no vibration. So if I put it in 4x4 without a rear driveshaft would I be ok to drive slowly home?
I need a answer ASAP, I'm flying out tomorrow(05/22/12)!!!
ASAP ASAP ASAP, Thanks you guys!!
BTW, its a Sterling 10.5, 3.73 gears. A maybe an open diff.??
Current truck
Late 2004 6.0L
ALL stock and I mean All stock!!
155,000 Miles and Counting
1999 Ford F-250 7.3L, My baby is sold!!
Extended Cab, Long Bed, White Paint
6 Speed ZF-6
35 Inch Tires
Shiny Wheels
4 Inch Exhaust
K&N/AEM Intake
TS 6 Position Chip
Fuel Bowl Delete
Fuel Regulated Return
International Cam Sensor
Pre/Post Fuel Filters
Valvejob is offline
post #2 of 4 Old 05-22-2012, 12:03 AM
JSchuricht's Avatar
With the drive shaft out the axle will still turn with the tires. You could potentially have something lock up while going down the road and loose control. If you pull the axle shafts out it would prevent that, but I still wouldn't recommend it.
JSchuricht is offline
post #3 of 4 Old 05-22-2012, 06:50 AM
spool up that turbo!!
hollister25073's Avatar
You could pull the axles make bolt on covers for the axle ends drain the oil out of the rear end clean all the metal out of it to avoid ruining bearings on the drive home refill the rear end pull the drive shaft then limp it home
01 f250 4dr LB 6spd
s&b, cfm+
4in straight pipe
DP tuner
boost pyro and engine oil temp
AIH delete, hpx, frx
05 harleys 8000k's
billet grille and painted shell
17"welds and 35-12.5's toyo mt's
cab lights
southbend con ofe waiting to go in
fresh 7.3 from reviva
SOLD
1995 f150 302 5spd 35's sad sad day
hollister25073 is offline
post #4 of 4 Old 05-29-2012, 08:09 AM
LiftItUp's Avatar
this happened to me on sunday. just left myrtle beach pulling a 38' 5er about 400 miles from home. pulled the rear drive shaft put it in 4 hi and headed home. it clanked real loud and i took it easy until the noise stopped at that point i knew all the teeth were broke off and took off. drove interstate speeds all the way home, i hated to do it but you gotta do what you gotta do. i bet i was about the only person in the country pulling a 12,000 camper with a front wheel drive
07 ccsb lariat 4x4
Lifted 35s
Bone stock for now
Traded
late 99 ccsb lariat 4x4
6" procomp
37" m16s
4.88 gears
tw
autometers
diy intake 4" MBRP cat delete
foil delete
LiftItUp is offline
