Rear end help - Ford Powerstroke Diesel Forum
Old 05-03-2012, 06:30 PM
Rear end help
When i put my truck in drive or reverse the rear end pops like a u joint is bad but that cant be what it is i had my trans rebuilt about 6 months ago along with all the u joints anybody have a clue on what it is?
I would greatly appreciate it
Old 05-04-2012, 03:39 PM
Is there not any rear end specialist out there
Old 05-04-2012, 05:38 PM
It's not uncommon for the slip yoke to make a popping noise, try pulling the dust cover and greasing it.
Old 05-05-2012, 01:02 PM
I had thought about that is there a alemite on it? And a special grease have to be used?
Old 05-05-2012, 01:09 PM
I bet it's the slip yoke, as long as it's a 2 piece drive shaft.
I drilled and tapped mine so I could grease it.
Old 05-13-2012, 11:49 PM
i had all my ungreaseable u joint go bad in 8 months have had the grease able ones on for almost a year.. but i grease them every 2 weeks with marine grease
Old 05-18-2012, 09:48 AM
I just had the same thing happen my rear end started popping I tore it down and the bolts had came loose in my rear end carrier assembly some had broken off not a common problem but its worth taking the rear diff cover off and taking a look
Old 05-18-2012, 12:26 PM
Could be slop in the spider gears
Old 05-19-2012, 10:26 AM
I took it off about 2 weeks ago to change the grease and looked over everything good besides the bolts dang I guess I'll take it off again
