4wd issues
1K views 2 replies 2 participants last post by  asian195
#1 ·
OK I just bought an 01 250 4x4 and I went to test the 4wd today and to my surprise it didn't work. Truck only has 70k on it. I was doing some reading and it sounds like the vacumn lines seem to be a pretty notorious problem with the auto selector which mine has. When I switch it into 4wd only the passanger side will spin. I haven't tried putting it in lock position yet because I have to take the wheels off because of the rim cap is blocking it. Does this sound like a typical vacumn leak or what? And where should I look for the leaks. Sorry I'm a newb
#3 ·
Pull the vacuum line off one side of your hub and plug it. Leave the other side in auto lock, then test in 4wd. If it works you know the o rings on the side you disconnected are bad. If not, reinstall that side and repeat on the other side. If still nothing, you have a leak else where.
Sent from my PC36100 using AutoGuide.Com Free App
