pinion angle and driveshaft vibrations - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-23-2012, 02:25 AM Thread Starter
juggy_08@hotmail.com's Avatar
i have a 6 inch lift in my SD and ive replaced the driveshaft with new one experimented with tapered blocks and no success also a negative on the drop kit for carrier bearing i found some info that the pinion angle should be the same as tailshaft on transmission can someone fill me in on this? if so nontapered blocks would fix the vibrations im having right now? my pinion is parallel with driveshaft
Late 99 f250 CC SB
w/6inch lift 35s,
4inch turbo back w/6 inch tip,
DIY 6637 intake
bullydog dog programmer
DIY boost fooler
wicked wheel
ford reman 4r100
glowshift gauges boost egt trans temp
ebpv delete
1.0 exhaust housing
juggy_08@hotmail.com is offline
