03 F250 SD will not move in any gear. Help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 03-19-2012, 07:05 AM Thread Starter
I was pulling my buddy's excursion out of the mud, I was in wet grass. I was pulling him out backwards, I was in reverse facing him. I pulled kinda hard, my 37s never even spun. The blow off valve was loud when I let off the throttle, the truck shut off tho. It is automatic! I started it back up and now it will not go forward or reverse. I got it towed. I tried many things like unplugging neutral switch, checked every fuse. I tried rocking it, maybe it was stuck in some gear, I reset the battery 10 hours. I am at a loss. This is my baby! Is there a relay or some switch that could be bad? It has clean/full tranny fluid. I can hear the RPMs change when I switch gears, just wont move! Help
project tt is offline
post #2 of 8 Old 03-19-2012, 07:07 AM Thread Starter
btw it is a floor shifter for 4wd
post #3 of 8 Old 03-19-2012, 09:01 AM Thread Starter
I unhooked the read tranny line to see if check valve ball was stuck, wasnt. Towed it forward and tried to get it going, also reverse. There are no leaks. I think it may be something electrical with the torque converter?? Any help would be great.
post #4 of 8 Old 03-19-2012, 08:03 PM Thread Starter
wow ok thanks lol ttt
post #5 of 8 Old 03-20-2012, 10:58 PM
Colotow's Avatar
Location: Quit Iraq, got a house in Tooele, Ut, Back in a big wrecker playing in traffic!
sounds like the transfer is either in neutral, or the shaft between then broke/stripped.
what does it sound like if you put it back in park while idling, a clicking/grinding sound that stops after a couple seconds, or no sound?
also, check your transfer linkage
99 F350 CC DRW 4x4 PSD 6 spd 4:10 Programmed, 4"exh, 8" lift Kelderman 4 link air ride rear, southbend clutch (and arm!) 295/85R22.5's, AFE stgII gauges, push bar, 07 lights, recon smoked fender and rears, ARE shell, DynaTrak combo front,
, Short throw Shifter, Airdog, Regulated Return fuel, Coolant filter, Bypass Oil Filter. Next:BB Turbo, CAC, Injectors, HPOP, Head studs, and anything else I can afford
Colotow is offline
post #6 of 8 Old 03-20-2012, 11:03 PM
I say trans case too.
8" Skyjacker lift
2" wheel spacers
22" American Racing rims
40x15.5x22 M16's
DIY intake
Zoodad Mod
4" strait exaust
Glowshift gauges
DIY Boost Fooler
Unplugged wastegate
TS 6 position chip
dr8082 is offline
post #7 of 8 Old 03-21-2012, 02:40 AM Thread Starter
No sound. Grinds a tiny bit switching from 4h to 4l
post #8 of 8 Old 04-22-2012, 10:31 AM
sounds like mine did trip from dallas to san antonio, cept i just didn have reverse, torque converter went, fried it bad, towing 25ft toy hauler, was my old 250, fried the next one too as pump went out less than 1k later. i will tow to somewhere next time, ford house was a nitemare, was only place close and open on sunday.
Keith
E99 F350 Lariat CC DRW, 82k, 4" Diamond Eye turbo back w muffler delete and 6" Monster Tip, S&B Cone air filter, 60 gallon RDS aux tank, glow shift tri pod pillar pod, 6.0 trans cooler, aluminum finned rear diff cover.
02 VStar Classic 1100, braided lines, Cobra Exhaust, Memphis Shades shield, chrome fender bumper, saddle bags, modded air intake and filter, blue w grey flames on fenders and tank(daily driver)
07 Malibu (hers)
fourx4forfun is offline
