Cracked Trans Housing - Ford Powerstroke Diesel Forum
post #1 of 9 Old 02-21-2012, 12:11 AM Thread Starter
So long story short, i drove home from school 2 hours away and when i got home was letting the turbo cool down, so walked inside to say hi came out and the truck was pissing out transmission fluid. This happened about a month ago but not as bad, it was the gasket in between the transmission and the transfer case. So i got it towed back to that show cause i thought they just screwed it up or something. Turns out i cracked my tranny housing towards the tail end. My tranny guy said thats where that most pressure is in the trans cause thats where reverse is. Also told me it couldve been from pulling a trailer or something along those lines. Well i havent pulled a trailer in quiet awhile and im skeptical why this happened but my question is has this happened to anyone else? Cause if theres reasons why it cracks there id like to know about it and what i can do to prevent it
2000 F350 Ext Cab Short Bed
4" turbo back to 8" stack
Turbonectics Ballbuster Turbo
TS Chip tuned by Tony Wildman
K&N Aftermarket Intake
20" Monster XD
35" Nitto Mud Grappler
Zoodad Mod
Harpoon Mod
Marinco Mod
Stroking is offline
post #2 of 9 Old 02-21-2012, 05:09 AM
Is it even worth it???
ABOBB's Avatar
I've done it 3 times!!
I would bet money, that it's cracked across the top of the case, about 6-8 inches from the flange where the transfer case adapter bolts on.
Tell the shop you have it in, that they need to check for any, and every possible source of driveline vibration. That means u-joints (on both driveshafts) and also to check for pinion and carrier bearings issues on both axles.
What causes this is the fact that the transfer case does not have a mount, but hangs from the back of the transmission. Any driveline vibration causes the transfer case to vibrate, as well, and over time the aluminum transmission housing work hardens, and finally cracks.
ABOBB
Aaron A. Bobb
2002 F-250 SD ExCab, Short Bed, PSD, Auto trans, 4X4
Custom tuned 6 position Chip
Whelen CSP690 Strobe Kit (Installed @ Feb Indy Strokers Rally... Thanks Adam), ZooDad Mod
COMING ATTRACTIONS:
Heated Side Mirrors, Owner Built Rear Airbag System
Owner Built Front Bumper, Owner Built Tymar Intake
Owner Built Custom Exhaust, Rear Roll Pan?
ABOBB is offline
post #3 of 9 Old 02-21-2012, 10:24 AM Thread Starter
does anyone make an aftermarket bracket that would keep that from happening?
20" Monster XD
Zoodad Mod
Harpoon Mod
Marinco Mod
Stroking is offline
post #4 of 9 Old 02-21-2012, 11:48 AM
ABOBB's Avatar
Not that I know of, but I haven't really researched that either... would be nice.
ABOBB
Aaron A. Bobb
COMING ATTRACTIONS:
ABOBB is offline
post #5 of 9 Old 02-21-2012, 12:26 PM Thread Starter
Yeah definitely, but my mechanic did go through my u joints and he said he couldnt find any that are bad but i do know that in my front axles the axle seals are bad, would this effect it at all??
20" Monster XD
Zoodad Mod
Harpoon Mod
Marinco Mod
Stroking is offline
post #6 of 9 Old 02-21-2012, 12:40 PM Thread Starter
But now i think about it my hubs are always unlocked so that part of the axle isnt spinning so i dont think it would effect it
20" Monster XD
Zoodad Mod
Harpoon Mod
Marinco Mod
Stroking is offline
post #7 of 9 Old 02-21-2012, 01:20 PM
CSIPSD's Avatar
Never cracked a tranny housing in 1.5 million miles...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 9 Old 02-21-2012, 02:10 PM
ABOBB's Avatar
I've killed 3...
First one, had a bad u-joint in the rear driveshaft, had a vibration, that I couldn't find with the driveshaft in the truck, and finally killed the truck.
Second one, u-joints were ok, but I think that the bad u-joint (it was the rear) got the pinion bearings along with the transmission the first time around, another cracked case was the result of vibrations coming from the bad u-joints... pinion was pulling back in the housing and bouncing off of the carrier.
Third one was my own fault, didn't get the pinion torqued correctly when I put new bearings in, and those vibrations came back. Haven't torn it apart yet on this time, but I'm sure I need pinion bearings along with a transmission.
ABOBB
Aaron A. Bobb
COMING ATTRACTIONS:
ABOBB is offline
post #9 of 9 Old 02-21-2012, 08:18 PM Thread Starter
I wish i could say i didnt crack my transmission
20" Monster XD
Zoodad Mod
Harpoon Mod
Marinco Mod
Stroking is offline
