To much play in steering!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 02-16-2012, 04:32 PM Thread Starter
On my 01 f250 i have terrible steering play. i can turn it 90 degrees both ways. How can i fix this because im constantly having to drive with the wheel alomost sideways to stay in my lane or to correct something. Thanks
PowerStrokeKid0736 is offline
post #2 of 6 Old 02-16-2012, 05:54 PM
aussie=effie
bob harris's Avatar
steering
get the steering box adjusted and go round and tighten up all the bits, ball joints worn ??
bob harris is offline
post #3 of 6 Old 02-16-2012, 06:29 PM
Quoted: 14 Post(s)
Turn the truck off, leave it in gear/park, put the e-brake on and crawl under the front end. Have a buddy shake the wheel back and forth fairly hard and watch all the tie rod and link ends. Should be pretty obvious what's wrong.
ttyR2 is offline
post #4 of 6 Old 09-10-2012, 11:35 AM
Yer Nut !!!
Check the Nut that holds the pitman arm to the steering box, bet it's loose. Mine does the same thing, has a lot of slack when the nut lossenes up.gonna buy a new steering box,, others that had the issue suggest an aftermarket box,,, buut I forgit the name of the comapny that sells the 'good one'.. RB
XR-2001 is offline
post #5 of 6 Old 09-10-2012, 12:31 PM
I needing a new box, so if you get namepost it. ,
jchaussee is offline
post #6 of 6 Old 09-10-2012, 12:56 PM
See message below, the Red-Head box gets a lot of high regards around Ford owners it seems------
We do have that gearbox in stock and the price is $346 exchange plus $175 on the core until we get yours back. Ours come adjusted and on center- if you feel that there is any problem please do not adjust on the gear, and just call us.
Thanks,
Harvey Foster
Owner
Red-Head Steering Gears, Inc.
(800) 808-1148
XR-2001 is offline
