Major Issue with Hub - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-15-2012, 07:56 PM Thread Starter
Guys I need help bad...I bought a set of Warn hubs to replace the factory autolock hubs. I sprayed both hubs with PB Blaster every night for about a week to loosen them up. Anyways, drivers side was easy as pie. Fast forward to the passenger side. Took the retaining ring out, tapped lightly on the hub on both sides, tried to wiggle the hub out and it wouldn't budge at all. Sprayed with PB Blaster again, let soak, still nothing. Tapped a little harder on the hub and it actually cracked the housing. So now I can't get the hub out, and I don't want to tap on it anymore and completely break the hub apart. What should I do?
Eric
ewatts2003 is offline
post #2 of 4 Old 01-15-2012, 08:08 PM
Nashotah7's Avatar
Tap it hard and let it break away......You have new ones right? But before you go to put in the new one I would sure figure out why the old one wouldn't come out. Bad axle shaft putting pressure on the splines? Bad hub bearings? Something isn't right there, and I don't think it is just corrosion. Good luck.
Nashotah7 is offline
post #3 of 4 Old 01-21-2012, 10:22 PM
Johnny Law Brown
jc82chevyman's Avatar
I have seen them things come out real hard before they make a tool to remove them but I usually just put atwo pair of vise grips on each side lock em down tight and pull hard and hope I don't fall off my seat
2002 F-250 IH 444E
AFE Stage II
GTP38R
4" TB exhaust
35" BF Goodies
1995 F-250 IH 444E
jc82chevyman is offline
post #4 of 4 Old 01-21-2012, 11:27 PM Thread Starter
I've tried two pairs of vise grips and hoping they don't slip...I think I'm going to ruin a couple pairs and weld a plate between them to connect a slide hammer to and try to get it out that way...snow is coming so I need to get it done asap. Thanks guys.
Eric
