squeaking and vibration when in 4wd - Ford Powerstroke Diesel Forum
Old 10-26-2011, 04:09 PM
When i put my truck in 4wd i get a squeak and a vibration i can feel in the floor.anybodyknow where i should start ?? Truck is an 01 f250
Old 10-26-2011, 04:19 PM
Check your u koints in the front drive shatf for play. And also u joints in the front axle
Old 10-27-2011, 07:15 AM
All the joints look good. could a wheel bearing goin bad make that noise?
Old 10-27-2011, 07:45 AM
In the Ft Axle, there's a double U-Joint (called the Cardan Joint) that has this, spring-loaded, Ball & Socket that will squeak. You'll have to pull the DriveShaft to check it though (It'll squeak in you hand sometimes....)
Next, try locking your hubs in manually (if your 4WD) and see if that eliminates the vibration as a test for bad needle brgs.
