torque converter shutter or axle wrap
I have searched already and and I can't find an answer to my question.
My truck: 2003 F250, 7.3 auto, crew cab short box, Tuff country level kit in front, One 4 inch tall block in the rear and a set of BDS add a leafs in the rear. 315/75-16 Kelly safari tsr My problem: I get vibration/shudder from the rear when accelerating from a stop until 15mph. no matter how fast or slow I accelerate. there is NO shudder when stopping or when accelerating at any speed other then from a stop. also it did not happen right after I lifted the truck. What I have done: the carrier bearing is shimmed down 1-1/4 inches and the two pieces of the drive shaft are .8 degrees different from each other. The u joints are less then a year old along with the trans from jasper. I just greased the slip joints and changed the rear diff fluid and added a container of friction modifier. The trans is full and the fluid is bright red and smells like brand new. Questions: Torque converter shudder or axle wrap? How can I tell the difference? |
I would love to know the answer to this, I have the same problem, never really bothered me I am just curious what it is.
I had the same thing happen to my truck until I replaced the rear u-joint..also got better mpg! I can still feel some vibration at low rolling(0-10mph) speeds but that's from my tires.. If you have axle wrap you would feel the back of the truck lift up a lil when ya pin it.
I suffer from the same issue..... thought it was just part of the lift, big tires, etc. Then again, I don't know that much about these big trucks, etc.
so after a tip from someone on another forum I zip tied a webcam underneath my truck so I could see what the rear diff was doing when I was driving. differently axle wrap, the drive shaft flange on the rear diff gets at least 2 inches closer to the bed when I go from dead stop at about half throttle. you can watch the diff return to it normal position at the same rate at the shudder decreases. I am buying a set of bolt on One Up Off Road traction bars and thank you everyone for the help.
| Tags |
| axle wrap, tc shudder, torque converter shudder |
