vibration at 55-35 decel - Ford Powerstroke Diesel Forum
Old 10-16-2011, 12:22 PM
if it aint one thing its another. anyone had this problem? while going 55mph then letting it coast down it just shakes/rattles like no other and when u get back in it it smooths out. just did a water pump u joints, carrier, changed the diff oil. after my pull in north carolina my stock tranny is now slipping but i wouldnt think it would be the trans shaking the truck. im stuck i might just drive it till she breaks and then i will know what the problem is. just seein if someone else has simular problems.
Old 10-16-2011, 02:35 PM
Not sure but u could easily check the u joints on the drive shaft.
Sent from my fone.
Old 10-16-2011, 02:37 PM
The Tamed Racing Driver
99% probably the u joints
Old 10-16-2011, 02:46 PM
Almostdunfukinwidit
Ujoints Josh.
Old 11-18-2011, 07:14 PM
does the truck need to be lifted in order to check the driveshaft u joints?
what is the best technique when checkin them?
Old 11-18-2011, 07:41 PM
The best technique would be to pull the driveshaft out and "feel" each joint manually for sicking/roughness. Its only a few bolts and its out, not very difficult, just mark on the rear and the trans where you took it apart.
What my uncle did was to jack up the end of the truck and put it in gear and have soneone look at the shaft while he recreated the condition when it would vibrate. You could see the thing jumping up and down, pretty cool!
