Front end rebuild - Ford Powerstroke Diesel Forum
Old 10-08-2011, 03:00 PM
Front end rebuild
Truck is a former plow truck so front end needs work.
I started tearing my front end apart to change out ball joints, looks like I need seals too. Currently I have everything off except the spindle? where the ball joints mount, the crown nuts are frozen on. I also would like to change out the UV's while it is apart too. I don't know how hard that would be though, haven't done those, but I did the ones on the shafts so I'd like to do these as well to know they are done.
It also seems like the sway bar needs some help as I can slop it side to side about an inch+
---Are there any kits you guys would recommend?
---One question I have is how much drag should the hubs have? None, a little or what?
Thanks
Brian
