1 peice drive shaft? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-30-2011, 12:33 PM Thread Starter
Ray Bennett's Avatar
Im about to get my two peice drive shaft built into a one peice in hope of getting rid of some hi speed vibration I can not get rid of. My flange to flange distance is 74 inches. Would you have the shop put in a cv joint or will the slip yoke be just a s good? any advice is appricated.
Just bought!, 1997 F350 CCLB 5 speed manual, For now the only mod is the 4" straight pipe
2002 extended cab long bed 7.3, 3.5" lift with 37x 12.50 Terra Grapplers on 17" Pro Comps, ts 6 pos chip, 05 grille, DIY 6637 air intake, 4" MBRP exhaust with muffler delete, Built trans with PI TC tugger shift kit and suncoast 5 disk drum, custom made one peice drive shaft, Edge CTS
Ray Bennett is offline
post #2 of 8 Old 09-30-2011, 08:59 PM
Quoted: 14 Post(s)
That's a lot of work to "hopefully" get rid of the vibration. Find a good driveshaft shop and have them balance your stock driveshaft after checking the CV joint and u-joints for damage.
ttyR2 is offline
post #3 of 8 Old 09-30-2011, 09:16 PM
jesilvas's Avatar
Quoted: 2 Post(s)
We have CV joints?
Also, if you have a slip yoke, you then have a two piece drive shaft. Unless you're talking about the part that slides in the trans tail housing.
I want to go the one piece route, mainly for one less ujoint and no carrier bearing to mess with.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #4 of 8 Old 10-24-2011, 07:34 PM
one piece driveline?
there is good reason for the two piece drive line and carrier bearing, your driveshaft angles are very important, and setup incorrectly will not only add to your vibration problem but it could potentially destroy or decrease the life of your entire drive train. make sure you have a highly skilled mechanic at your side!
1999550
Jeff99F550 is offline
post #5 of 8 Old 10-26-2011, 04:28 AM
cghoerichs's Avatar
It's also a 2 piece to allow for your truck to flex under load and the drive line to slip with the flex. A 1 piece will not slip to adjust to the flex under load.
Mulberry Grove Family Farm
2002 7.3 4x4 C1 Axle
Warn Premium Manual Hubs
cghoerichs is offline
post #6 of 8 Old 11-28-2011, 10:17 AM
cowpuncher's Avatar
After reading all the rest of the posts I thought I would throughout one more reason we have a 2 piece driveline. Also if a driveline is too long it is more prone to imballance I had to really beg my driveline shop to build me a 50+ inch one that i had built for a suburban. I understand the carrier bearing and ujoint cost thing but think about it so does Ford and they worry about the pennies that the parts cost when building them they really do use all the extra pieces for a reason even when me included think they could have done it better
Its the long skinny pedal on the right Cupcake
cowpuncher is offline
post #7 of 8 Old 11-28-2011, 11:00 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Doesn't the new SDs use a single piece shaft?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 8 Old 11-28-2011, 11:05 AM
cowpuncher's Avatar
Not sure they could be if so then good point and then I would definetally suggest getting one built with the newer truck tubes and other parts to fit the older trucks.
