Brake pedal not coming clear up, brake light stays on - Ford Powerstroke Diesel Forum
Old 08-18-2011, 05:54 PM
The brake pedal appears to be staying down just enough to keep the brake lights on in my truck. We're talking maybe a 1/16" down. Is the only solution to replace the brake light switch? I assume it has a spring that is supposed to push the pedal back up just that tiny big for the switch to turn off. Is that correct?
I was going to lube the brake pedal pivot, but it doesn't look like there's an easy way to get any oil into the bushing.
