need steering help
I have a 01 f250 4x4. My steering has a bit of a catch in it. Its not as smoth when turning as it use to be. I'm not sure what it could be. Any suggestions? I have plenty of power steering fluid. Could it be the pump? I'm just not sure. any help would be great. Thanks!
Steering box maybe? Have you checked to make sure your steering joints are all tight and not worn out?
check to make sure your balljoints, tierods, and front axle universals are all good and not biding. Then, flush the power steering, and refill with fresh ATF.
nothing is lose. i will try flushing out the fluid
I'm having the same problem .I found out that my front u joints are stiff from lack of use. There are no grease fittings ,so the only fix is to replace the joints . I locked in my manual hubs last night and made many figure 8 turns in a school parking lot and it loosened them up pretty good , but will have to replace them , I just bought some extra time I guess
I jacked the front end off the ground and put jack stands under for support. Lock in your hubs and spin the wheels and turn left and right , If its the u joints , you'll see the wheel jerk. Rotate your steering right to left to get the full range of motion out of the u joint, you'll see the stiffness ,its quite obvious.
