rear hub leak
After replacing hub seal twice I have decided that the fiber type will not hold synthetic grease. Problem is I have already removed factory wear ring. the new skf seal i aquired from nappa is a rubber lip type but came with no wear ring . Any one have any experience with this or know if it will be fine with no wear ring? 2001 f 350 2wheel drive
Thanks tony |
Okay found retaining nut had came off. replaced nut and seal still leaking. does anyone have any thoughts on this issue? Or know any thing about the factory wear rings.
