Front Axle Questions, Misc Fluid Questions - Ford Powerstroke Diesel Forum
Old 05-03-2011, 05:02 PM
Winning DUHHH
Hey guys, I was under the truck the other day and decided to for some reason wiggle the front axles up and down, On the drivers side I get about 7/16 to MAYBE a 1/2" vertical movement, and the passenger side has 3/8" to 7/16" vertical movement. IS this normal or not? 4x4 works fine, no binding, chattering, popping etc.. no unusual wear.
Other questions.
In your all opinions, whats the best fluids for the
ZF6 / Any additive?
Front Diff / Any additive?
Rear Diff / Any additive?
Thanks again guys,
Tony
Old 05-04-2011, 06:26 AM
Totally normal, nothing to do with wear, they moved that much when new
Old 05-04-2011, 06:36 AM
Winning DUHHH
Thanks, just wasn't sure. Any recommendations on the lubes?
Old 05-04-2011, 06:42 AM
i know the rear takes and additive i usually use a oil that has it mixed in already vehical specific
Old 05-05-2011, 01:45 PM
Winning DUHHH
Anyone Else. Whats worked best for you all
